Good Rules of the Road
Discussion in 'Motorcycle Talk' started by Beerbohm, May 10, 2005.
  1. Rule 1: Alcohol drinking and sportbike riding do not mix and never will.
    Rule 2: Stay at least 5 to 7 bike-lengths behind the guy in front of you.
    Rule 3: Ride in staggered formation behind the guy in front of you. If he is in one "tire lane" you should be in the other one. Whenever he switches (for whatever reason), you should switch opposite of him.
    Rule 4: Passing others and the occasional high-speed blow-by is fine. Just do that stuff in the passing lane of the highway and use your signal lights so everyone around you has an idea what you are up to.
    Rule 5: When changing to the passing lane...please check behind you...somebody else may be in the process of blowing by from behind.
    Rule 6: Use your turn signal lights liberally!!!
    Rule 7: Riding side-by-side is strongly discouraged unless you are communicating something to someone for a brief moment (at slower speeds of course).
    Rule 8: Avoid riding if your bike is not in tip-top shape: bald tires missing brake levers (Right Fighterama), bad brakes, etc., can ruin a ride for you and us too.
    Rule 9: The most important rule of all: Don't allow those (evil persons) up front to cause you to push beyond the limits of your riding skill!!! If you feel you're getting to that point, back off & fall back! No one is going to laugh at your or leave you behind (there is someone probably back behind you anyways). In fact, rather than laugh...you will be given due respect for making responsible decisions.
    Courtesy 1: Point man and any of the group running point with him should wait up at turn-offs to keep those trailing behind on the right roads. It's a drag to be on a ride and get lost because you were left behind.
    Courtesy 2: Indicate road hazards to those behind you. Learn, use and watch for the common "body signals" to indicate hazards such as pot-holes, gravel, road kill, "approach me", "back off" and of course: "Oh shit...the cops!".
    Courtesy 3: Point man should occasionally allow the ride to be relaxed so that everyone can re-group and enjoy each other's company. This excludes when beans is point man, no one could hold him back.
    Courtesy 4: Be brave & tell someone about any safety concerns you may have with them - and don't get pissed if someone feels they need to talk to you about their safety concerns with you.
    Courtesy 5: Ride safe-minded with the attitude all the time that your life and the lives of those around you depend upon it, cause guess what...it's a fact. There is a time and place for "letting loose" and a time and place not to...so be cool & demonstrate to the rest of the group that you know when those times are.
    RIDE SAFE!!!
    Some Wise Bike Notions
    Counter Steering
    If you push the left bar, the bike goes left.
    If you push the right bar, the bike goes right.
    That is, unless you keep pushing the right bar all the way,
    then you will probably go left while the bike swaps ends.
    Crashing
    Remember riding isn't inherently dangerous... crashing is.
    The Sidelines
    It's always better to be on the sidelines wishing you were on the track than on the track wishing you were on the sidelines.
    Fuel
    The ONLY time you have too much fuel is when you're on fire.
    The Rear Wheel
    The rear wheel is just a big fan used to keep the rider cool and his butt relaxed. If in doubt... watch. When it locks up or slides out you can actually see the rider start sweating and pucker marks are left on the seat.
    Too Slow
    No one has ever hit something too slow. (There was this one time on 5-9)
    Rides
    A 'good' ride is one you can walk away from. A 'great' ride is one you can walk away from and use the bike again.
    Getting Hit
    They can't hit you if you're not there.
    Mistakes
    Learn from the mistakes of others. You won't live long enough to make all of them yourself.
    Side Stands
    Pull in quick, kick the side stand down, jump off the bike and hurry away...an awful crashing sound is then heard. Enough said?
    Center Stands
    You know you've left the center stand down when you're in top gear at 4000 rpm going nowhere.
    Traction
    When traction is sparse, the probability of survival is inversely proportional to the angle of lean. Large angle of lean, small probability of survival and vice versa.
    Your Brain
    Never let a motorcycle take you somewhere your brain didn't go five seconds earlier.
    Fog
    Stay out of fog. The single red taillight you think is another rider ahead that you can catch, might be the red starboard light of a docked boat.
    Parking
    Always try to keep the number of times you park the bike equal to the number of times you've ridden it.
    Luck & Experience
    You start with a bag full of luck and an empty bag of experience. The trick is to fill the bag of experience before you empty the bag of luck.
    Mirrors
    If all you can see in your mirrors is the direction you were previously traveling intermingled with sparks, and all you can hear is commotion from the passenger riding pillion; things are not at all as they should be. You may have lost your pipe (who was that again).
    Other Objects
    In the ongoing battle between objects made of metal, rubber and plastic going dozens of miles per hour, and the ground going zero miles per hour, the ground has yet to lose. Same holds for cars, trucks, walls and most animals. Draws don't count.
    Judgment
    Good judgment comes from experience. Unfortunately, experience usually comes from bad judgment.
    Going Forward
    It's always a good idea to keep the headlight end going forward as much as possible.
    Looking
    Keep looking around. There's always something you've missed.
    Laws of Nature
    Remember, gravity and centrifugal force are not just good ideas. They're laws not subject to repeal.
  2. those are good and some funny
    Mike
  3. Extensive list, where did you get it?
    Experience riding with people you know can allow some of those to bend if you can basically predict someones movements or have had enough time to know their style well.
    E
  4. He is going to hit me right about....... NOW! "sorry sorry sorry sorry sorry"
  5. That is a long list. The only two things I really emphasize:
    The person in front of you ALWAYS has the right-a-way. Do not pass in the same lane unless motioned to do so. Otherwise, pass in an adjacent lane.
    And please oh please oh please people...if you see a road hazard of ANY sort, kick your leg out directing people behind you to be aware of it. For example, if the hazard is in the center, and the front guy kicks his right leg, the second guy kicks his left leg, and it follows down the group. That way the rider in the far back (especially on large rides) is always warned.
    I think Eric is the only rider who alerts riders for hazards as much as I do!
  6. Hell Boys....I have learnedtthree things...Beer talks ALOT :director: beans is a born leader :king: and when I grow up I wanna be just like fighterama :bump:
  7. Shut up 8 mile (Alstar) you would not have it any other way. [​IMG]
