Jafar's Ducati
Discussion in 'Mechanical & Technical' started by beansbaxter, Apr 25, 2005.
  1. Why does it clank and rattle?
  2. Ask's the retarded (j/k) valve setup they've got! Just the signiture duc-call
  3. Jafar
    i think its the clutch that does the clanking and rattling; cause its dry. all the plates rattle around with the vibration.
    i'm pretty sure the valves make the ticking sound.
  4. jezterr
    cuz it's jafar's bike...
  5. The princess has a dry clutch, so when the plates arent compressed they hiss and slide around inside the teeth on the clutch assembly, but when they are compressed they click with each revolution of the motor. It sounds like a broken connecting rod or a bad valve, but its a beautiful song to racers and desmodromic nuts.
  6. The Pope died, Italy shut down afterwards, the Duc is feeling the effects of it.
  7. Let me guess...Str8 cut gears....right
  8. That avatar made my pants tight.
  9. I can send you the jpg.
    I have the same pic of carl foggerty giving the bird :thefinge:
  10. Every ducati with a dry clutch does. Pull in the clutch and it goes away.
