Shift points explained
Discussion in 'Mechanical & Technical' started by bitabur, Mar 31, 2008.
  1. Hey all, this was an old post of mine that I ran into from the hayabusa.org message boards about 2 years ago. I thought I'd throw it up here and open it to anyone's critiquing. If you disagree with anything here or have anything to add, let me know.
    You can calculate mathematically when the best time to shift is.
    We know that the gearing change when shifting to the next gear is going to reduce the torque output because you are shifting to a higher gear, meaning a higher torque divider. We also know that the torque output of the engine is going to fall near the top of the powerband.
    Lets set some variables:
    Tc = torque in current gear
    Tn = torque in next gear at same (wheel) speed
    Gc = current gear's gear ratio
    Gn = next gear's gear ratio
    The time to shift is when:
    Tc = Tn * (Gn/Gc)
    If you take your dyno'd torque graph, multiply the vertical scale by (Gn/Gc) and multiply the RMP scale by (Gc/Gn), the proper shift point from one gear to the next is where the two cross.
    This makes the assumption that your (actual) speed will not change while shifting, which is not exactly true. I believe pushing the actual shift point a little higher will tend to compensate for this.
    Does this make sense? I'll make some pictures of what I'm talking about later if it doesn't.
    continued in later post of mine...
    Even if you don't want to dyno your bike, the liklihood is that your shift points will be almost the same as a stock bike. Get someone to post their baseline dyno and it should be pretty quick to analyze...
    Anyway, I made some pictures, so I'll try to explain this as clearly as possible. Vertical axis is ft-lbs of torque, Horizontal axis is engine RPM.
    Lets say you have this stock curve (and I know this doesn't look like the busa's curve, we'll get there):
    If we want to calculate the shift point for this curve for the 1 to 2 shift for the busa (1st gear is 2.615:1, second is 1.937:1), we need only stretch (compress) the picture by (ratio 2/ratio 1) vertically, and by (ratio 2/ratio 1) horizontally, and then overlay the pictures. Stretching horizontally means you're matching the RPM scales of the pictures to the speed that the bike is moving, while stretching vertically means you're matching the scales of the pictures to the torque that is being put out at the crank. After stretching, we get something like this:
    Then we can simply overlay them and see where they intersect:
    So if this was your torque curve, your optimal shift point would be a little between 8000 and 9000 RPM. The true optimal would be a little higher because the vehicle speed drops between shifts.
    Now, with a curve that looks more like the busa (at least at the end of the curve, which is the important part here):
    The torque peak is later and doesn't fall off as much. In this case, the stretched image (still for the busa's 1-2 shift) looks like:
    Now when I overlay the images, you can see that the curves never cross. In this case you would want to shift as late as possible (redline) to accelerate the fastest. I would guess that if you analyzed the busa's torque curves you would find this to be the case.
    It is also important to note that to perfectly calculate this, a dyno would need to be run in each gear, with the dyno's resistance equal to the force required to accelerate the bike itself. Changes in the speed of accereration offset the dyno results, because the engine is also accelerating its own reciprocating parts.
  2. This is a very good explanation of how to calculate shift points :mfclap: because you are graphing the foot pounds of energy to the rear wheel rather than the engine torque. I have seen several graphs like this for specific motorcycles for all 5/6 gears and when an inline 4 engine is involved, the shift point is usually about 500 rpms past redline.
  3. Getting a little picky arnt we..... I just use that little red line on the tach or the rev limiter if I'm to busy to look down.
    B
  4. Some of us have shift-lights that can be programmed for a different RPM in each gear. Some of us dragrace and win or lose races by 0.001's of a second.
    To some of us, it matters.
    To most of us, it won't.
  5. Ok, I'll pretend...where can I get dyno charts for a VF1100S? or C for that matter?
    I've only bracket raced, so am more likely to be short shifting anyway.
    Simpler to use an accererometer than have bike dynoed
