Squeek
Discussion in 'Mechanical & Technical' started by Beerbohm, May 16, 2005.
  1. I have a 03 gsxr 1000 and when I give her some gas and let off there is a faint but distinct squeek comeing from the egine area. Mostly able to hear it while in nutuerel but can be heard while in gear as well. Any ideas
  2. jezterr
    hard on the throttle then off? short squeak? long squeak? does it affect the performance at all? could be the throttle bodies closing. or a mouse in your engine.
  3. easy on throttle. No performance change. I will set a mouse trap next to it. Short squeek.
  4. Some vehicles have various pressure sensitive parts in the fuel injection system that make chirps/squeeks/vacuum noises that are odd but harmless. Listen to any late model car, youll see what I mean
    E
  5. So what you need to do is put a mouse trap by your pipe!!!
    The problem is that exhaust valve, when you let off the gas and the rpm's drop the valve closes. dont worry about it to much it but you should have it looked at.
