Okay my 1991 XR250L is the japanese version so it is kickstart only, no battery but DOES have a lighting coil and full lights.
So basically think of it as an XR250R but with a lighting coil with 12V regulator/rectifier circuit.
The quality of the power is pretty inconsistent, enough to blow a digital turn signal relay and a little box to some rear LED lights that had them be running and brake lights. I've since eliminated that box and wired straight to the LEDs as run lights and those work fine.
I have a 12watt LED AUX light on the front with my main headlight that's wired into the highbeam. The output of this light varies a bit and seems to DROP with more throttle, which is a little odd.
Anyways, I'd like to put a capacitor somewhere in the system to help even out the power. On the USA versions of the bike that do have a battery, a common mod is to get rid of the battery and put a capacitor in its place.
I do not have any fuses whatsoever in the system, might want to add one as well?
Anyways, I just have no idea where in the lighting system I should put the capacitor. Any thoughts?
